ka-t oil line??
Miller White
Car: 1989 240sx
i am piecing my turbo kit together and i'm trying to find the easiest oil line fix. i started to order the jgs kit but it doesnt say anything about how the feed line works. if its the sand which style or the kind you have to screw into your oil sending unit or what? what other options are you guys running?
Chaluska
JGS utilizes a screw in style.. no sandwich adapter, but i used it for around a year with zero leaks
I did use a nissport adapter.. but it didnt hurt anything
92KA-T
Car: 96 240sx
92 240sx hatch -sold
i used a sandwich plate from ebay the o ring is poo and leaks oil.. which sucks.. oil lines tho i got made at a local rubber and gasket place.. coolant and oil lines ran me about 90 bucks with fitting and everything .. and everything is stainless steel braided except for the oil return.. so it looks pretty good for a decent price..
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
I used the JGS line kit with a Oil Tee from http://stealthmodeperformance....shtml
The setup works great, let's me run an Oil pressure gauge, and is steel(much stronger than brass) and doesn't leak.
