ka-t help!
Miller White
Car: 1989 240sx
i've just started on my ka-t build and i've been looking around trying to find out wat i need as far as oil lines. i'm using a t28 from my friends sr, do i just need a bung whole in the oil pan and the sandwhich adapter that goes on between the oil filter? thanks for any help!
WDRacing
The info is in the FAQ. I suggest buying the oil line kit from JGS, best kit for the money on the market right now.
WD
Miller White
Car: 1989 240sx
do you know how they do the feed line fitting? is it a sandwhich plate that goes on where your oil filter goes or what?
480sx
Car: 1996 Pearl White 240sx
WDRacing wrote:The info is in the FAQ.
1mansho
yes you can use the sandwich filter plate to plug in the feed line and i do suggest you use the jgs oil line kit.
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
Just buy JGS and save yourself the hassle. seriously it is straight forward with the JGS oil kit. no need to worry about going out to home depot to pick up parts and find out you wasted so much time.
