bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Thu Oct 11, 2007 2:19 pm
Good, good! Some more things to add to my list to check!
I was wondering about the TPS before, if I try to rev the engine up a little at idle, I am having to fight something that is continually trying to adjust it back to idle speed. I had never noticed that previously, so I thought it might be the TPS acting funny. I don't *think* the timing chain is the problem, or hope it's not anyway (fingers crossed). Once I get it above 2500rpm is runs perfectly fine.
The current cap and rotor are about 1.5 years old now, I will probably replace those next. I was also concerned about the distributor before. Whatever it is, it is something that is affected by both heat and possibly vibrations (some bad harmonics or something that makes the problem surface at certain rpms). At the moment, the car is actually getting very good mileage, 24-27, so that was leading me to think that whatever is messing up is not permanent, only happening during those periods. I'm not sure what, if anything, this would rule out though. My cat is pretty well shot right now and there is a hole in the exhaust ahead of the muffler so I get all sorts of interesting smells, but I'm pretty sure I've noticed a fuel-rich scent at times.
Btw, speaking of MAFS is a KA-E MAFS compatable with a DE? I have one of those in my shed.
