Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Sat Jul 09, 2005 2:27 am
The original filter does a great job filtering out the dirt. That is what it is designed for.
The K&N filter has an active filtering system, that uses oil to actively attract the dirt, while having a less dense filter media.
What that means, is that the factoy filter is fine, but must be changed more frequently, as it loads up, it becomes much more restrictive.
As the K&N loads up, it turns black, bit the pressure drop across the filter changes very little.
The oil does cause problems with the MAF only if you don't follow the directions, when you re-charge it. A lot of people clean it, spray the oil, then put it on the car (I used to). I would end up having to clean my MAF about every 2 to 3 months. Then, I went to a 2-filter system where I would clean and oil the first filter, and let is sit for a year while I used the second one, then swap it out and clean the other one. I keep my spare in the original box and plastic bag.
For the last 2 years, I have not had to clean the MAF.
If I were you, buy 2 or just buy 3 from Wal-Mart, and chan ge them every 4 months.
