silviamaniac »
https://forums.nicoclub.com/silviamaniac-u9235.html
Thu Nov 13, 2003 3:00 pm
I think the JWT ecu is worth the money.
We downloaded the JWT ROM from a SE-R ecu, although we are not sure if we downloaded it correctly, but what i can say is, they do whatever they state they will. Yes the chip is 10bucks that you can get from the market, but the program isnt that simple as someone might think.
One of the feature that other couldnt take out from the ECU is the "tip in retard" and "speed limit". And it is "plug & play" too.
eManage does remove speed limit, but with all the harnesses and software, it even more expensive to hav the JWT ROM. eManage tend to serve those who really know what they are doing. JWT is for idiot like me :P
As an example, JWT can tell your injectors to pump certain amount of fuel on specific psi. With rising rate fuel regulator, you only go by ratio.
And, I do not hav a JWT ROM yet.
