just got back from dyno
1SlowCA18DET
is a sr t25 really worth or should i save a and a s25 t28?
Dattebayo
S25? wtf...
biosehnsucht
I would assume he meant s15 ..
Dattebayo
In that case, the S13 SR turbo would work great for you. There are plenty of documented cases of +220 RWHP using one of those. The T28 is better (or course), but other modifications will have to follow the upgrade. And they aint exactly "cheap".
Nunook
on an sr t25 I got practically the same numbers as u, but ur front mount and piping is probably better then what i had. my ECU is chipped so my afr came out better looking.
Complete Props. It might be time to upgrade ur maf.couple of questions??? unless u dont wanna release secrets.wat timing r u running? wat front mount?stock fuel regulator? wat spark plug heat-range and gap?
float_6969
Hey, they didn't happen to use SAE correction on that did they? That doesn't apply to Forced induction vehicles.
1SlowCA18DET
timing was set to 10btdc cause wrong info form another site, evo 8 front mount, stcok fuel regulator, a step cloder pulg.
biosehnsucht
SAE correction is wrong for turbo cars? I've never heard of this..
float_6969
biosehnsucht wrote:SAE correction is wrong for turbo cars? I've never heard of this..
http://www.sdsefi.com/techdynojet.htmSecond to last paragraph at the bottom of the page.
And if you want a better description of what exactly it ishttp://www.i-speed.us/technica...shtml
It's basically an equation that corrects for different temperatures and atmosphereic pressures. The problem is that in a turbo charged car, the air entering the motor, isn't ANYTHING like the ambient air. The pressure is generally kept constant due to the wastegate, and the temperature is going to depend more on the effeceiency of the turbo and the effeciency of the intercooler.
roe_wedge
Car: 1990 240 SX S13
how much is a T25? where can i get one?
biosehnsucht
figured it was something like that once you said it but I was wanting a more in depth explenation and it had never occured to me before, nor had anyone mentioned it to me..
fanta
Use this to better approximate power.http://home.austin.rr.com/turb...c.htm
float_6969
Great link Fanta, thanks!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
that statement that the CA has no torque is a load of crap. mine made a beastly 164ft/lbs at the rear wheels running 9psi on the stock .48 t25 and a 6:1 air/fuel ratio. i can definately believe those numbers. congrats, im jealous and you really have a ringer of a motor there!
- tim
