well i preped the engine bay by cleaning it down with some simple green from dollar store
let it dry , then took a scotch brite pad scuffed it all up , wipe off with wax and degrease remover ( picked this up at local auto paint store),
next i undercoated the frame rails let that dry overnight almost 24hours ( i used 3m professional undercoating can pickup local autozone and its paintable )
used some black primer since i am painting it black let dry , then through down some urethane acrylic base ( Black), then Mid clear Flake , let dry for about 2 hours, then i hit it with some
Speed clear with a fast hardner since i dont have a paint booth for it to dry
the most important thing to do is scrub your engine bay till you can say you would eat off the engine bay before you paint
also read directions the auto paint store prints out for you , Recoat windows are very important and set dry times are important as well , remember if you air dry double the time
any more info you need just ask
