evildky wrote:Timing, belt, tensioner, idlers, plenum hoses, water pump, cam and crank seals. Not a bad idea to have the heads freshened. The only real difference in models is the auto's came with slightly smaller cams, and the 96 lacked the VVT, otherwise they are all the same. Your stock diff is fine.
