:: orion :: wrote:Here's the deal:
OEM are high impedence.
If you go to top-feed, you can buy high impedence 50lb'ers, and they are plug and play (with the correct clips, that is).
72lb'ers are typically low impedence, and require resistors to INCREASE the resistance to make them function properly, and not burn out the injecotr drivers.
That is, unless JWT has modified your ECU to use peak-hold, low impedence injectors and you have high impedence ones...which is unlikely.
Later - Brian
Make's sense, but I always remembered JWT referring to them as dropping resistors? Yet, they increase the resistance? Oh well, their idiots.....
Ey B, I'll hit you up tomorrow, got a question.
