nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sun May 22, 2016 8:36 pm
IS it just clicking and then sometimes cranking over?
Have you check fuel pressure? What is the PSI? It needs to be around 40psi(not sure of exact number) Is pressure regulator connected?
Have you made sure you have spark? Is the CAS attached?
Make sure you attach all the connectors CAS, PTU, CTS, etc.
The clicking you have an issue with the starter engaging, bad ground, bad battery, bad connection.
The cranking and not starting could be no spark, no fuel, too much fuel(are the plugs wet? also try holding down the throttle while cranking), ignition fuse blown, bad connections, bad fuel injectors(should ohm between 10-14, not higher not lower), bad computer(have you checked for codes?).
