J30t muffler problems
wpritcher
I was just told I need a new muffler for my 1997 J30t. I was quated a price of almost $1100. Most of that was for the muffler (over $1000). Are there no aftermarket mufflers for the J30?
What other options can you suggest.
driverdriver
Car: NICO's longtime resident Canuck!!!
If there's one in your area, try a custom exhaust/muffler shop, they can hook you up with a muffler for considerably cheaper.
Q45tech
Junkyards for a complete oem system............what did you hit they last 15-20 years.
wpritcher
I don't recall hitting anything, but I haven't actually seen the damage yet. I plan to look at how bad it is before have do anything. Thanks for the info. Will let you know
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
probably just loose at the connection after the diff.
NY_Pito_NY
you know i have the same problem with my 95 j30... my problem is the downpipes...i cant even get the soldred.... need to find down pipes after the manifold.let me know what you find out
Eswift
Car: should be obvious enough
Q45tech wrote:Junkyards for a complete oem system............what did you hit they last 15-20 years.
stainless welds will rust after 10 years in the salt belt.
madmax88
Car: my car
just put a magnaflow stainless exhaust on my J30 nice ,but it cost $2200.00 CAN. looks real cool.
cweberj30t
Car: 1993 J30t
2003 G35
2007 G35X
2011 G37X
Madmax- Did you go 2-1 or duals? I'm thinking of an exhaust upgrade in the spring and wanted to know what others have done. Post some pics.
madmax88
Car: my car
2 inch 1/4 pipes, duals all the way,real sweet!!!
diamondj30
Car: Not to low , not to high , just right .
2 inch 1/4 pipes, duals all the way,real sweet!!!same here.high flow cats,borlas,15 bluestreak glass packs as resonatore to dial in the buitiful sound.a sound that doesn not refleck off overpasses,perfect.no drone at all.and daul angle ncut nrolled edged tips.looks stock.cut out on both sides under bumber.
