Yeah, keep us posted!!! I've heard of the VG30DETT swap, but a LS1????naladude911 wrote:WTF!!!!!!!!!!!!!!!!!!!!!!!! POST PICS, HOLY ****, THIS IS INSANE!!!!! AN LS1 SWAPPPP
yes you can...i currently am running an aeromotive tsunami submersible fuel pump hot wired in....it was $200 from summitGregGold wrote:I am working on installing a '2000 SS camero motor (LS1) in my 94 j30t and am needing to know if the stock fuel pump is capable of delivering 58 psi, which is the standard operating pressure of the LS1. Can anyone advise me here?
Also, I read in the j30 manual that the fuel system is controlled by the ecm, which supposedly, adjusts the voltage or amperage to the pump, controlling fuel pressure. Am I understanding this correctly? I am not planning on running the j30 ecm. So, can I send the fuel pump 12volts and expect it to work normally?
I appreciate any help.
Well take pics!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! This is the first major swap ever done on a Y32 possiblyGregGold wrote:I have the engine and trans mounted, the shaft in, trans shifter linkage in. Looks like the stock j radiator hoses will work. Not sure if the j radiator itself will be enough, but given the ls1 has an aluminum block and heads, I dont think it will require what a cast setup would. I have the a/c lines ready. Just got the ls1 harness and ecu redone - removed the security and unnecessary stuff, etc. Power steering is done. I didn't mess with the rear steering system.
Not much time to work on it, but its moving along. Almost ready to hear it run. Curious if the stock fuel pump will do the job or not. Don't have any pics.
Once you drop in the LS1, you won't need nitrous. Comes with enough horsepower to pull the boat. If I'm not mistaken, the '00 Camaros weigh slightly less than the J.mels95j30 wrote:THIS IS GOING TO BE A BADASS SWAP !!!!!!!! me n one of my buddies was talking about putting an LT1in my J but i was like naaaa you pull this off ill do it too i make the money for it lol peaceeeeee oh yea then shoot that bishhhhh lol 100shot
That would be the other infiniti pig, the Q45.GregGold wrote:I was under the impression the j weighs around 4,000 lbs. Is this the case?
PRESSURE is not necessarily important, its the FLOW RATE of the pump.. You can run it at whatever pressure you want and it wont damage anything, but if the pump cannot pump enough fuel then you're gonna be in trouble. Of course you need the correct pressure for the injector timing to work fine, but thats not really whats important, its easy to crank the pressure up...GregGold wrote:I have the GM 4l60e transmission, which is an ls1 option. As far as fabbing, I had a reverse sump oil pan built and had to work on the left manifold to go around the steering. Simpler work included motor/ trans mounts, trans shift linkage, power steering and a/c lines and the driveshaft made. Need to figure out how to wire the fuel pump and see if it will produce enough pressure.
Just a guy from NY that doesn't believe we really do things bigger here in Texas.GregGold wrote:ca18datsun510,
What is your point?
Greg Gold
