Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Jan 16, 2004 3:53 pm
The injectors, ignition,ecu, sensors and fuel pump consume 16 amperes alone.........that is 40% of the alternators output at idle.Turn the lights,radio, and heat on and there is little or no capacity left.Rear window defroster is a negative as is running the fans or headlights on high.
Even at 60 mph it is possible to drive an hour with a breakeven or net loss or slight gain in very cold or warm weather,,,,,the fan speed is the key.
Measure the battery voltage [everything off] :State of ........... Specific........... Voltage Charge............ Gravity........... (12 Voc) ---------------------------------------------------------------100%.......... 1.265....... 12.68 75%.......... 1.225 ...... 12.45 50%.......... 1.190....... 12.24 25%.......... 1.155....... 12.06 Discharged.......... 1.120....... 11.89
