J30 transmission Pan Bolts
yodawill2000
Car: 94 Infiniti J30
Anybody know if the J uses one time bolts on the transmission pan ??Plan on dropping it tonight and wanted to cover my bases so to speak.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
I have dropped the pan on both Js 3 times since I have owned them and never replaced the bolts I just put a little blue RTv under the heads. The manual does say to always replace bolts because they are self sealing.
yodawill2000
Kewl Thanks Got a ton of blue RTV around.
I was a nervous nelly dropping the pan thinking I would find a ton of clutch crud in there.But there was just maybe a 1/2 teaspoon of uber fine greymatter on the magnet.RELIEF !!!!
The kit had the wrong dang gasket though
I'll pick one up from the stealership tomorrow.put the pan on with 4 bolts to keep any debris out till then.
Question.
what is the the little feeler thingie on the front passenger side inside the pan ??I thought it was the dipstick at first but it isn't.
It moves straight up and down.
Modified by yodawill2000 at 4:59 AM 8/22/2008
J30inthe sun
Car: 1997 J30
yodawill2000 wrote:I'll pick one up from the STEALERSHIP tomorrow.
Modified by yodawill2000 at 6:54 PM 8/21/2008
That is the funniest thing I have heard all day
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
[QUOTE=yodawill2000]
Question.
Could be the fluid temp sensor-- BTW advance auto and napa have the gasket for around $7
yodawill2000
Kewl.I got the filter kit from Autozone.Filter and O-Ring were a perfect match.Gasket was way off.Weird.
