fourdrinie »
https://forums.nicoclub.com/fourdrinie-u26512.html
Tue Apr 14, 2015 11:09 am
Before you take the fuel pump out....
the fuel pump runs for about five seconds when you first turn the key to the on position.....have someone put the key to on...while you are listening with an open trunk with an ear next to the gas tank, or near the gas filler neck with the gas cap on...
check to see if youre getting voltage to the fuel pump...there are two wire clips attached to the top of the fuel pump lid...get a voltmeter and check for voltage when key is turned to on position for first five seconds...
It might be a fuel pump relay located under the front hood, or the fpcu, located to the right of the fuel tank in the trunk
