escavetta »
https://forums.nicoclub.com/escavetta-u11912.html
Wed Dec 10, 2003 5:25 am
hello again- I think I have fixed G20's leak. After checking under the ceiling liner, and pulling off my glove box (to no avail), I took off the carpeted trim just in front of the door hinge (where the "Nissan ABS Ltd." device is located) and found the bottom end of the sunroof drain hose (clear plastic tube) sitting there. Apparently, it had gotten pulled out of the drain hole within the frame in front of the door, moved to the inside of the car, and then trim had been replaced on top of it, such that it was hidden from view. (I do not see how it could have gotten there on its own, as the trim had to be physically unscrewed to squeeze the tube under it). The scary thing is that I have only gotten my car serviced at the local Infiniti dealer. (I won't name names, but it is near San Francisco). I hope that it was an oversight and not done intentionally. I re-threaded the hose back into the car's frame, and so far it seems that the car is dry, but I cannot get the musty mold smell out. This might be a place to check on yours cars as well...
