here are some older pictures of it..
zerothread?id=294497
Parts List:
Suspension;Stance Pro CoiloversNismo PowerbraceTraction Rods - Unknown Brand, came with the car.RUCA - Unknown Brand, came with the car.Tension Rods - Unknown Brand, came with the car.SPC Toe RodsDC Sports Front Strut BarWelded bar between rear strut towersStitch welded front endProgress Front and Rear sway barsSPL steering rack bushingsSPL solid subframe bushingsSPL Tie rods and ends
DrivetrainHKS GP Pro Twin Plate ClutchAluminum Driveshaft4.08 ring gear + helical from a s15fake B&M shifter
EngineEngine Block built by Mazworx (2.2L)CNCd combustion chamber (90mm)Darton SleevesCP 90mm PistonsEagle Rods w/ ARP studsGreddy head studsARP main studsPower Enterprise 90mm Head GasketNismo Motormounts reinforced with liquid nailsgreddy oil panCustom Topmount setup w/ a gt3076r .64
HeadTomei 260in 270out procamsBC valve springs and retainersnew valve stem sealsEnjuku rocker arm stopersTomei solid liftersFake Greddy intake manifold70mm sr20de throttle bodypeak performance intake runner gasket
CoolingGodspeed intercoolerKoyo RadiatorRX7 oil cooilernismo thermostatgreddy radiator cap
BrakesAluminum 300zx 30mm brakes front and rearR33 emergency brake cablesAluminum 300zx rear spindlesAgency Power Brake lines17/16 300zx Master CylinderAxxis Ultimate Ceramic brake pads
Gauges and TuningAutometer Ultra-Lite Boost GaugeAutometer Ultra-Lite Oil Temp GaugeAutometer Ultra-Lite Oil Pres. GaugeAutometer Ultra-Lite Water Temp GaugeAutometer Ultra-Lite Voltage GaugeInnovate wideband kitEnthalpy Tuned ECUSAFC2HKS EVCIV electronic boost controllerHKS Full Auto Turbo Timer
FuelSard FPRWalbro fuel pump740cc Deatschwerks injectorsz32 maf
AeroVersion Select IV body kit30mm front fenders50mm rear fenders
InteriorSilvia Seats and Door PanelsMomo Steering wheel and horn button
MiscGreddy Oil Catch CanBattery Relocated to TrunkGutted AC (heater still works)JDM folding power mirrorsJDM rear window visors ("Silvia" lights up in the window)
i know i am leaving a few things out of that list...
