Victor »
https://forums.nicoclub.com/victor-u94029.html
Sat Aug 02, 2008 10:26 am
I brought my J30T into a transmission place to get a flush. They wanted $125 for the flush, clean the pan, new gasket, new filter, all fluids, and disposal fee. However for the flush part all they did was drain the fluid, refill it, run the engine a while with the wheels off the ground so the transmission could be shifted back and forth from drive to reverse with the engine running, and then drain the fluid one more time. The guy said if a transmission has a drain plug this is how they do it, the only time they hook up to the transmission cooler lines is if there is no drain plug. The filter Napa sent them didn't look like the original, the original was solid metal and the replacement was half plastic, half metal. The mechanic said he would rather just wash the original and reinstall it so he gave me a $24 credit for not using the new one, but said he would try to get an OEM type and would install it next week, including another new gasket and new fluid for the $24 he just took off the bill $101.00 total.My questions, is his method of flushing the transmission acceptable? If I didn't want to clean the pan and install a new filter I could have just drained the old fluid and put new fluid in and done basically the same thing myself. In fact, in the future I think that is all I will do as he said my old fluid was O.K. except for being a little dark from normal wear, and the only dirt in the pan were a few metal filings stuck to the magnet.Second question, should I go back and put a new filter in if he does manage to get one that looks exactly like the original? One benefit would be I would get the fluid, or at least whats in the pan, changed one more time and a brand new filter, but he showed me the old one after he cleaned it and it looked perfectly good to me, and the screen wasn't clogged up. I would have to pay back the $24 and waste another hour or so of time waiting for him to redo the job.
