Is the stock clutch from Nissan weak? I think I burned mine up.
Nissan 350z / Nissan 370z general community discussion forum
RCAnismo
Car: '06 Nissan 350Z Enthusiast, '05 CBR 1000RR Repsol, '03 Jeep Grand Cherokee
I had a racing clutch in my last car and I don't do the 1/4 mile very often.I went to the track for the first time with the Z to see what she would do and I think I burned up the clutch or seriously took some life off of it.
I dumped the clutch at around 5 or 6K rpm and kept going thru the gears. At first I thought the tires were just spinning b/c I was taching it out and not really moving then I realized I was just burning up the clutch. It smelled horrible.
So I'm thinking about investing in a racing clutch even though I've never felt it slip on the highway and it just turned 26K miles. Has anyone switched out the clutch for a performance clutch? Any recommendations? Or is the stock clutch good and I'm just a moron at driving and shouldn't dump it? or do I need to adjust it? Any info is appreciated here.
LAKE ERIE Z32
Car: 90 Nissan 2+0 300zx TT, 13 ford taurus SHO (TT AWD)
the stock clutch in mine had some good grip.... but when i got my new transmission put in (had the grinding problem and got a new 0 mile trans for $50) i had them throw in the ACT street disc clutch and i love it.
Exar-Kun
Car: 2005 350Z
THe stock clutch is actually quite strong....mine never had a problem with 7 track events, some modifications (see below) and 50k miles on it. A friend of mine used the stock peice with a supercharger with no problems as well...sounds like one of a few things might be happening:
-You need to learn to launch better without tappering the clutch and burning it.
-you may be feeling the dual-mass flywheel effect obgging a bit...I broke my springs after my 4th track event *shrug*
I just put in a Z1 clutch and flyhweel combo..pretty nice except the clutch itself was very tight and made the pedal too low (fixed now), and it's easy to burn and doesnt slip in traffic very well :/ However the added response and feel for track use was great....be wanred on the flywheel thing - you'll start hearing more gear noise.
-Chet
RCAnismo
Thanks for the suggestions, I think my launch had a lot to do with it. I was about to run again but I didn't want to try without test driving it on the street. It seemed fine afterwards so I'll probably go back to the track and try to fine tune my launch.
Murdered_T
Car: 1979 Datsun 280ZX byach
The Nissan clutch plates are made by Exedy, if you pick up the Nismo clutch disk then its basicly buying the middle quality Exedy clutch disk, pardon my spelling, I have been drinking. Also, depending on the production date, Nissan put in what they called a self adjusting clutch plate which adjusted to the way someone dumped, or, slipped the clutch.
yelohandL
Car: 350Z 2008
hahahaha dat got me cracking, ^^ "excuse ma spelling, i have been drinking" o s**t dat was funny
Return to “350z / 370z Discussion”
