is my idle normal??
s0ldats
when i'm cruising to a stop sign, i usually just push the clutch in and shift to neutral. my question is that when i shift into neutral, the RPMs drop really really low...like 400-500 as opposed to its usual 600-800. After the car has stopped the rpms will rise back up. Am I driving wrong? or is there something wrong with the car?
kilipo4
Car: scuba diving, hunting, cars, women, drunkenness
you're not driving wrong. do your rpms waver while you idle? i would suggest searching the tech forum and the Nissan Online Mechanic forum for something to the effect of 'rough idle'. that's what I did and there's alot of good information out there.
let's see if i can summarize.
clean throttle body with carb cleanercheck iac valvecheck egr valvemake sure you're vaccum lines aren't leaking or overly soft
there're a couple other things you can check but these seem to be the biggest ones mentioned.
good luck,cliff
s0ldats
no....my RPM's just drop really low when i'm coming up to a stop light...and as soon as i stop, the go back to normal. other than that while the car is still... tthe idle is normal.
Nismo_Freak
Car: 89 Nissan 240SX
Brakes rely on vacuum from the motor ... the idle simply lowers itself when you apply brake pressure because of the pull on the motor. Its a normal thing.
s0ldats
whew thanks for the reply.
