It isn't really the engineers, it's their (admittedly necessary) dependence on CAD/CAM software in the modern production environment. The answer to "why" is simple: Every car today from a Tesla to a Fiat is designed by software to be assembled by robots -- not disassembled by people. I hate it but it's true.
Ilya... I know this post is 5 years old... but I was hoping you could help me out. It appears that my headlights aren't as bright as they were. Not sure if it's my imagination. The passenger headlight is only 5 years old, or so. Anywho... I went on the site and don't see the ballast you mentioned. I'm assuming they don't sell them anymore. What I did find was this: https://www.theretrofitsource.com/d2s-x ... quantity=1. Any idea if these are good? Will they extend the range of the OEM? Do I need anything else? I'm pretty clueless when it comes to ballasts as you can see.
Those should work with your current bulbs (which are D2S). The only downside is their form factor, it MAY not be able to be secured to the bottom of the headlight assembly like the ones I found.Big_Tone wrote: ↑Wed Jan 04, 2023 3:00 pmIlya... I know this post is 5 years old... but I was hoping you could help me out. It appears that my headlights aren't as bright as they were. Not sure if it's my imagination. The passenger headlight is only 5 years old, or so. Anywho... I went on the site and don't see the ballast you mentioned. I'm assuming they don't sell them anymore. What I did find was this: https://www.theretrofitsource.com/d2s-x ... quantity=1. Any idea if these are good? Will they extend the range of the OEM? Do I need anything else? I'm pretty clueless when it comes to ballasts as you can see.
Eh, I'm not a proponent of installing bulbs that weren't designed for that specific headlight. Our headlights (specifically projectors) were designed for HIDs. Not Halogen and not LEDs.Yoda's Master wrote: ↑Thu Jan 05, 2023 6:54 pmyou could also do a led conversion
https://www.amazon.com/LASFIT-Custom-10 ... B08GS6NR3Y
That's largely a problem with the bulb topology not matching D2R/D2S reflector shapes. Lasfit and Precision LED are now both making conversion kits with proper characteristics (even for D3 types), and there may be others I don't know about.Ilya wrote: ↑Fri Jan 06, 2023 7:20 amEh, I'm not a proponent of installing bulbs that weren't designed for that specific headlight. Our headlights (specifically projectors) were designed for HIDs. Not Halogen and not LEDs.
I had a 2013 Ninja ZX6R that was designed for halogen lights but had projectors. While the HIDs I installed were passable, when I tried installing $150 LEDs (expensive at the time), they were barely usable. Here is a comparison I did. As you can see, the LED high beam is not visible. Like at all. And the low beam is significantly worse than the HID low beam. I'm not saying the M56x headlight would display the same way, but it's best to stick to what it was designed for IMO.
Good to know. I have some LASFIT turn signals and they seem very high quality so good to know that they are taking into account those types of variables to ensure that the lights are useable and not impacting (negatively) others on the roadway(s).VStar650CL wrote: ↑Fri Jan 06, 2023 8:11 amThat's largely a problem with the bulb topology not matching D2R/D2S reflector shapes. Lasfit and Precision LED are now both making conversion kits with proper characteristics (even for D3 types), and there may be others I don't know about.Ilya wrote: ↑Fri Jan 06, 2023 7:20 amEh, I'm not a proponent of installing bulbs that weren't designed for that specific headlight. Our headlights (specifically projectors) were designed for HIDs. Not Halogen and not LEDs.
