Is my fuel management setup okay for...
fastpace
Car: cars of course
Hello all. I am going to be going ka-t and a couple of months and still thinking about some things before I go full throttle with this project. My main concern is the fuel management of the ka. What I plan to do is:
370cc injectors walbro fuel pump msd ignition system safc-ac hacked-maf
I plan to only run 4-6psi on this setup. please critizise this as much as possible.
MarkEmark
Car: fully-built '95 240sx KA-T
If you're only doing 4-6 psi, you don't need anything more than a fuel pump and a good FMU...but, if you're anything like me, you WONT be satisfied with 4-6 psi, and will crank it up a bit, so if you have the money, do the fuel system right the first time...I'd say yours sounds good up to 10 at least...
4felix20
Car: Emerald Blue S14
hacked MAF? is that just when you cut the screen off....i'm confused.
red240ne
Car: mmm...donuts
4felix20 wrote:hacked MAF? is that just when you cut the screen off....i'm confused.
no, search about it. It's where you have 2 MAF's but only one is actually functioning. Don't know much about it personally.
Nathan
More commonly it's where you increase the size of your MAF (while retaining the stock sensor element) the same percentage as you increase the injector size.
MarkEmark
Sorry for the thread hijacking/n00b questions, but after you hack your MAF/get new injectors, you need a whole new ECU tuning ($550!!!!) as well, correct?
Nathan
The idea is to get around needing your ecu tuned for it...the larger MAF fools the computer and balances out the larger injectors. It seems to work OK although I personally feel more comfortable with my sizeable turbo system/engine investment getting the ECU re-tuned.
fastpace
Car: cars of course
I was thinking of getting my ecu retuned also. But that is kind of pricey. But I know it will be a safe setup. Well how does this other setup I was thinking of sound.
370cc injectorswalbro fuel pumpjwt upgrade ecustock maf
i wanted to thank everybody so far for their comments so far.
Nathan
That's a good setup and one that they frequently do at JWT...the only change I would make would be upgrading the MAF. BUT, if you can actually stick to 4-6psi then your original idea should work pretty well. It's just hard to stick to your guns on the boost setting :D
bbandit
i heard JWT ecu tends to run richeven tho its safe, you're gonna have bad gas mielage and loose a bit of horsepower
best bet is to run JWT ecu + S-afc
or.. just run stock ecu + S-afc or any other piggyback, the drawback to this is that you're still gonna have have the speed limiter and speed governor in the stock ecu
another thing to worry about is retarding the timingi havent done much research about this but i think MSD make boost type ignition or somesort
but for 5-6 psi.. i think running "hacked mafs" + s-afc is good enough
Nathan
This is true, they do tend to run a little rich and a lot of people DO use an S-AFC to tune them down a bit. They have to back their product, hence they tune it a little conservatively, something I'm fine with, I'll just turn up the boost...75# injectors dont run out of juice for a while ;)
nissan
What 370cc injectors fit the ka24e?
