iliketocrash wrote:now that the weather is nice again i decided to start working on my car some more. this time i noticed while running the engine that i get a sort of rapid a consistent knocking sound at around 2500rpm but only when i the throttle. if i let off the throttle and let the revs drop the knocking isn't there. its kinda hard to tell if its my crank or not because i'm running an open downpipe and some stuff my not be bolted down securely but the knocking seems to consistent and rhythmic to be anything else. also, i noticed the knocking a lot more with my ear over the two coil packs nearest the firewall. oh, and my car still runs like ***. looks like i might be scrapping this project.
If you're hearing knocking at 2500 and it's a consistent rattle, then it could very well be a rod bearing. I tried to explain in my other thread about the issue with a ceramic clutch and the issues itmay pose.
Do a compression test and see if the #3 rod bearing is a bit on the low side? If so, you may just be able to save your engine by removing the oil pain and replacing the bearing inserts. Hopefully it's not that, but just a figment of your imagination. Good luck with this and keep us posted.
Dee
