kmckis1029 »
https://forums.nicoclub.com/kmckis1029-u103545.html
Wed Apr 18, 2012 12:35 pm
based on how it functions, you would have to bypass the main headlights' wiring as i bet they are both powered by the same wires, just that the fogs have a seperate switch/relay on them. Check out the FSM for your car... all you have to do is "jump" the fog light power wire to an "always on" source like the ignition wire or "memory wire". Make sure you Jump the wire "behind" the switch/relay of the fog lights else they would be on when ever the car is on LOL (some might want that...)
you can do this without cutting any wires with the use of a wire tap.
edit:
oh one potential side effect i noticed when i rewired my sidemarkers to blink with the front turn signals...
the Auto-dimming feature of the HeadUnit/nav/radio could be effected... like when your fogs lights are on the HeadUnit/nav/radio might think the headlights are ON and Auto-dim the Screens in the car. I personally havent looked into this much as i just turned the auto-dimming feature off as a work around til i get time to figure out how to stop that behavior.
