gordonq45 »
https://forums.nicoclub.com/gordonq45-u11011.html
Sun Feb 22, 2004 11:47 pm
Hi,
My aged Q45 is back for help!
Last year, my 90 Q45 had an engine light on problem that was not steady (see the thread "Try to understand my aged Q45"). At that time, I can not make conclusion what problem it was because the ecu code was not available.
Now the same problem pup up again. The car stalls on the road several times, but I can restart the car by press the gas paddle harder and drive the car with engine light on. The RPM is not stable that jumps up and down with the engine light on, especially at around 2000 RPM. I checked the ECU twice that shows the same code as 11 (one long and one short). I cleared code from ECU memory after first time to make sure the result is new code, not left from before.
Please help to make some suggestions:
Is it definitely the Crank Angle Sensor problem?? I read several threads on this forum with similar symptom and each one had little different reason such as MAF, fuel pressure regulator etc.
If it is the CAS problem, what is the proper action to fix it? rebuld? repair or replace it?
Can I do it by myself or I have to send car to a shop? If it can by done by DIY, I can call Joe for the parts. What is the procedure to remove the CAS?
Thanks,
