intermittent problem 86 z31
A home for 1983–1989 300ZX owners!
abstractjunction
Car: 1986 Nissan 300zx N/A
1987 Nissan 300zx Turbo
its happened here and there but it just happened again and stopped after i left the car shut off for like 20 mins i was pullin out i was in 1st or second gear rpms got up to 23 to 2800 then just totally lost power rpms dropped i kept pressin on the gas after about 5 seconds there was power again and got up to 23 to 2800 rpms again and did the same got to a parkin lot sat in nuetral kept foot on gas and it just kept doin the same thing rev up bog down couple secs rev up bog down always from about 23 to 2800. was thinkin fuel pump or throttle position sensor? any ideas? i just put some 8.5 spark plug wires had 8s on there b4 it started happening 2 or 3 months ago 1st time thought it was just water freezin in the lines put some gas treatement w/water remover went away then it would come back here and there when i would fill up on gas as soon as it started warmin up outside it didnt happen as much till wat just happened
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
could be a fuel pump, the way to test it to hook up an inline pressure gauge so you can verify pressure when the issue presents
could also be mas, or the tps, first thing I'd do is check the ecu for codes
abstractjunction
yea the codes in there were the same from the summer when i checked them(which would have thought a new one would have popped up) idle control circuit open or ecu and cant remember the other could the inline pressure gauge just hook up in series with the fuel filter?
evildky
06 Nissan 350Z GT
yes, just get some extra fuel hose and an inline fuel gauge
sraVGnotch200
Car: '84 Datsun 200sx VG30e
Ive got an 84 200sx with a vg30e from a newer 200. I have had this same problem going on and have been even before I swapped over to the 86 ecu and maf. For a while the car had been running decently after disconnecting the o2 sensor. Thinking this was the culprit I changed the 02 sensor yesterday but after plugging it in and driving it a while the same problem arose: engine falls flat on its face if you give it gas or it will eventually go through the revs if you really give it gas. But then, after disconnecting the o2 sensor again it runs and drives mostly normal. Any suggestions? the ecu is giving the "no malfunction in circuit" code 44 any help would be golden ;)
-Cam
evildky
06 Nissan 350Z GT
unpluggin the O2 richens the mixture, so you either have a bad maf, ecu, or a timing issue
Return to “300ZX (Z31) Forum”
