pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Thu Aug 18, 2005 3:11 pm
Definitely sounds like a bad ground, get wire and ground the ecu and see if it improves. get a ohm meter and ohm out all your ecu ground directly to the negative terminal on the battery (you might need to extend the black wire), this way you will isolate any false or week grounds that you might have around the ecu area.
Good luck,
PULSAR GTRRafi
