interior question
Nissan 350z / Nissan 370z general community discussion forum
jaym5k
Car: 2003 NISSAN 350Z TOURING
Does anyone know the name of the panel that is where the glove box would be on a typical car? I have a big scratch on it and I would like to replace it but cannot seem to find it anywhere or even what it is called. Has anyone ever removed it, if so how hard is it? Thanks.
R350Zz33
Car: 2008 350z enthusiast
try dash board, and i believe there is an airbag behind there if so it should be a PITA to remove
bmike818
Car: 2007 Z
R350Zz33 wrote:try dash board, and i believe there is an airbag behind there if so it should be a PITA to remove
This could be considered as an insult. If you don't know, you really don't have to post anything.
to answer your question jaym5k...
Its called the "Instrument Passenger Panel Lower"
if you need info on the lower panel check this out IP-13 http://www.nicoclub.com/FSM/350Z/coupe/2003/ip.pdf
dasoupdude
Car: 2005 Nissan 350Z
BlackSmoke
Car: 2007 350z Grand Touring
ohhh bmike FTMFW. . . hold on wait . . I cant catch my breath. +72 bmike
marlin29311
Car: 2008 Infiniti G35x
Return to “350z / 370z Discussion”
