Interior LED Light Swap
CPM.06.G35S
Car: 2006 Infiniti G35 Sedan S
Hi guys -
I am wanting to change all of the interior light to LED. i think that they look much nicer than the oem ones that are in now. couple questions -
has anyone done this? source/model of bulbs?
can i just directly replace them? is there any modification in terms of making an LED light compatible?
thanks.
cm
mks8882
Car: 2003 G35, 1995 F150
I took the original bulbs out of their twist in housings then put a LED in each ones place. However you have to wire up a resistor in series with the LED because the LED runs at about 2.2V instead of 12V. You can find some 12V LED's but I really doubt you will find an orange one in the size you need.
smockers83
Car: 2006 G35 Coupe
you don't have to do any modifications. there are lots of LEDs out there that will go right in just like any other bulb. i know JDM makes a whole bunch of LEDs and super LEDs in different colors, just do a search on google, i can't remember the site i was at earlier...i was looking into this as well. the trick is getting the right ones.
