loystock wrote:I added an AUX jack in my son's 97 I30 several months ago for his MP3 player. I did it in a hurry as my son was only home for a couple of hours so I was not able to document it. I bought a jack, SPST switch from Radio Shack (I have wires at home). The AUX jack connection is Tip to L+, Ring to R+ and then a Common connection to L- and R-. I remember connecting the RXD and TXD to the SPST switch. I believe in some HUs, the connection is between TXD (or RXD?) and Ground. However, in my case, the RXD and TXD terminals were not on the PCB so I have to use the CD Changer receptacle pins. I bought sockets from Fry's, crimped with pliers to make them snug with the pins. and then insulated with shrink tubing to prevent short circuit. I'll try to find the wiring diagram I used for the installation.
Hey guys,
Forgive me for resurrecting an old thread. I realize that many of you have probably moved on or have forgotten what you did to get this to work.
I have a 99 infiniti i30 with the stock radio and cd changer under the passenger seat. I have never used the cd changer and I have absolutely no desire to. So with the desire to add an aux switch and the information in this thread I took the plunge. I removed the cd player from under the seat and disconnected the connector. I figured that I would do something similar to what loystock did except just plug my wires directly into the female end of the connection that was still under the passenger seat. This way I wouldn't have to deal with getting to the back of the radio.
As soon as i got the connection apart and came back in the office to compare them to what was posted here, I quickly realized I had the same issue as Vladim. My pins did not match up with the op's pins. My connector has 12 pins in use but can actually hold 15 pins. The diagram that dbaxRonin linked has only 12 possible pins. Not to be daunted, I took the CD changer apart to get to the circuit board to find the labels for each pin and this is what i find.
L+ | R+ | S.GND BAT | x | ACC
L- | R- | GND | x | BUS-REQ | TxD | RxD | x | x | GND
So, now I can follow along with what Loystock said and put the L+ to tip, R+ to ring and L- and R- together to ground. This would wire the aux jack. But I am at a loss with the SPST connections since I don't have a Aux-On Signal input. I'm not opposed to trial and error, but I am opposed to shorting out my radio and not having anything to listen to in the car. With that in mind, I figured it was time to register and ask my question.
So, here goes.....With my wiring diagram and connections and with the lack of an aux-on signal input, am i able to put a SPST switch to get this to work and where would it go?
Thanks and sorry for the long post and the resurrection of an old thread.
edit..I just re-read one of loystock's posts and think I may be able to figure it out. So I guess I will just buy the parts needed and give it a go.
edit 2....ok, so i tried to connect the RxD and TxD to the STSP and nothing at all happened when i flipped the switch. I'm stumped at this point. Hopefully someone checks this post.
