07V84Z wrote:No one...Nothing? Oh well, it's not like its hurting anything I guess.
One potential cause is that the keyway has widened a bit so that the lock will release the key without actually being all the way in the "Off" position. I had a car once where this was so bad you could remove the key with the engine running.
Assuming the S has the same key receptacle as Intelligent Key setup, try wiggling the knob after removing the key to see if the motion will lock it into place.
The upshot is, if your car is still under warranty, take it to the dealer.
I've actually got a similar problem with my SL/Intellikey. It'll sometimes beep when I close the door, even though the key is in my pocket.
Ron
