well considering the 3.5 gets 35 hp, half of that is 17.5, and the 2.5 would probably get atleast more than half so 20 hp seems like a good numbermcheddadi wrote:
I don't know why but 20hp seems a little too optimistic lol
it doesn't work for the altimas before 05. only for 05-09. check the PDF in the OP post.Dexion wrote:This is great, but will we actually see power gains? Will this work as the ECU tune from Technosquare or Greddy Emanage for the 3rd gen's?
I guess my question is, WILL IT ACTUALLY DO SOMETHING? IIRC someone tested the power pup and it did nothing to his 3.5SE?
How can this work for all Altima's from 02-09, the ODB port changed in 05-06 and its completely different for 07-09..
Hrmmm....
there is a wot limiter. it's been verified. before our only option for that was the BLITZ Throttle Controller but that thing costed as much as this and only did that.LinkNuc wrote:I don;t think there is a WOT limiter on our engines, it was for Torque Managment on the Titan IIRC.
yeah I mean this lolDexion wrote:If you mean the throttle closes by itself on you after 6600 RPM then thats different, that is there to protect the engine. Instead of bouncing off the rev limiter the car kindly takes your foot off the accelerator pedal
Deebo, go here http://forums.altimas.org/zero...m-est and look at the new price for the tuner. You missed out on the $307 price from yesterday, but they are still having the "30 off" promo that mcheddadi originally posted about and it's $317. BUT it ends TODAY!! 7/7 @ 6pm est. So if you are even thinking about this, I'd get it now if i was you.deebo422 wrote:I'm definetly interested!!!! In for a GB!
Any updates on this???
You are correct sir. But I think it's going to be worth itdeebo422 wrote:Damnnn I missed that nice offer!!! So they aren't out yet? So basically if i buy i would be pre-ordering......
I personally wouldn't raise my redline unless I knew that my internals could handle itDexion wrote:Alot of power can be gained from just leaning out the fuel mixture a bit since the stock ECU makes it rich if you add boltons to the car.
Since this VQ's power does not fall off raising the rev limiter to at least 7100 RPM's would be plenty to take advantage of the sweet spot in our power bands.
The VQ35DE's in the 2007 and up Altima's have newer parts as well. For one the heads are directly from the VQ35HR in the 350z (07-08)
Sentientbydesign wrote:As for dynoing a CVT... The most accurate way to get numbers off of the CVT would be to monitor the "gear ratios" through the run - I'm sure the ECU or TCM monitors this, just not sure how to extract the data. Taking that data and recomputing the HP based on the corresponding TQ for that RPM would give accurate HP numbers.
If the 3rd GEN VQ35DE can handle it. I am sure that the 4th gen VQ's can handle it as well.rich2342 wrote:Maybe you should look again. They climb up to redline then level off..
http://www.nissanclub.com/foru....html
Not a bad idea, but the accelerometer option has it's own flaws to contend with:1125Altima3.5 wrote:Rather than using a dyno, wouldn't it be a more direct (and possibly useful) to measure the CVT's wheel HP using an accelerometer? (you can buy a program for the iphone for $13)
I tend not to trust the dynos that much because there's so much variation in measured WHP between different makes/models of dynos. The accelerometer does introduce the driver factor, but given enough responses (and detail about mods) we should be able to get an idea of the max potential of the car. Physics don't lie!
Technosquare safely raised the redline from 6600RPM to 7100RPM in their ECU reflash product and nobody has ever had problems from it.
Sentientbydesign wrote:> Weight/Mass variances will cause different numbers to come up.
> Flaws in the accelerometer design can magnify greatly. I'm not sure why Apple would spend so much time and money on getting accurate acceleration when the purpose of that feature wasn't to accurately measure your car acceleration.
> No SAE correction factors. This means that ambient air temperature and relative humidity are not going to be taken account for between runs.
> Tire type...
> Oh and hopefully, all those who try this method are smart enough to keep it on the track. Using various streets is not only dangerous, but also inaccurate as the slope of the street will make a difference in acceleration numbers.
Its coming man, in less than 2 weeks. a bunch of us pre ordered it already, we saved a killing. msrp 449 and we paid 307 shipped.DaCoupe wrote:I hope this comes out soon
you've been living under a rock or what?http://forums.altimas.org/zerothread?id=435301bhs07c wrote:Where can you get it for 307? ill hve the money in 2 weeks
Thats fine, I have no plans of advancing my timing, just raising the rev limiter and tweaking the A/F ratio a little is enough.rich2342 wrote:
I was reading a thread in the g forum here were the engine was blown. He was modded with advanced timing and had had the crank position sensor replaced quite a few times. After that they blamed the mods and it was attributed to the advanced timing.
