WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Thu Oct 09, 2003 7:53 pm
Do you mean the mthod where you hold a stick and melt it with the torch, I believe its called soldering, different from electical I know. I suppose that method would work for IC piping, but not for a manifold. The thing with ARC, Tig and Mig is that they add a type of metal as well as melt and bond the surface actually being welded, if that makes sense. The soldering method will just bond things together. But I've used JB weld before on things, so I'm pretty sure your method would work. Its easy enough to find out if you have all the stuff already. Just grab some old piping and give it a shot.
WD
