PulsarDet »
https://forums.nicoclub.com/pulsardet-u30679.html
Fri Nov 11, 2005 4:51 pm
It's all depend what is your need cause a Z32 maf will flow about 450hp , it's quite a lot. If you take a maxima 89-94 maf it will flow about 325hp, both are 3". I would be best to have the ECU retune, cause when you use the S-AFC, it cheat the signal from the maf , but the ignition still use the same ignition that could cause some major isssus, at Higt boost, then might be a good idea to swap some DSM 450cc since if you upgrade the maf is for more power so on with the injector. If you plain to get more than 300hp do the upgrade, if not keep your money !.
If you do plain to get 325hpgo with Maxima maf, 450cc injectorIf you plain to get 350-370hpZ32 maf and still 450cc injector + AFR, or some 555cc injector
If more than that Z32 and some 720cc injector.
