gjohnson66 »
https://forums.nicoclub.com/gjohnson66-u40893.html
Thu Mar 29, 2007 8:28 am
Welcome aboard!!!
I've noticed that the majority of guys performing mods on their cars used the JWT pop charger/Z-tube combination. They've also gone with the Motordyne plenum spacer. If you like that route, then there are other manufacturers that excellent products as well...i.e. Stillen, HKS, Ingen, etc. These are very reasonable when it comes to the price versus power ratio.
If you want to go with the short ram intake (like I did), then I'd go with something like the Ingen CAI. It has a short ram version built into it -- but beware, it requires a LOT more labor to install than the above systems. For instance, you'll have to remove the bumper to access some of the OEM equipment you'll have to remove. That being said, I like the sound and perfomance I get out of the unit.
One last thing to consider, if you ever want to upgrade to forced induction, then I'd consider an intake plenum upgrade. I went with the Kinetix SSV unit and could not be happier. It looks great and I have gotten some great numbers from the install. And the best part is that it wasn't that hard to install!
I'm sure some of the others will chime in with other advice, but hope this helps answer at least a couple of questions.
