ken240sx »
https://forums.nicoclub.com/ken240sx-u27409.html
Fri May 09, 2008 8:33 pm
All of the above is easy. Yes there's a lower gasket. Just get an intake mani gasket set. I think that includes upper, lower, and TB gaskets. NY won't take emissions removal lightly tho on an OBDII vehicle...you may need to register your car in another state, or pull some strings. The only things you really need to remove emissions are an egr block-off plate and some gasket material you can cut to shape/size and some vacuum line plugs. If you plan to remove ALL vacuum based emissions equipment then yo may as well just get rid of all the hard lines behind the engine and on the mani. Make sure ALL vacuum ports off the mani and intake are plugged or you car will run like poop. I'd keep the IACV and the Blow-by tube...so you'll have 2 ports on the intake piping instead of 3 I think. And yes to remove the mani you need to unhook and move the fuel rail out of the way. Also, are you talking about polishing the inside or outside. I've done both. Polishing the inside is a PITA. I port matched the intake runners to the head first with a dremel, then I took a really hard circular wire brush on a long rod to the inside of the runners to scrape off all the gunk inside and also I was hoping to gain some minor volume increases in each runner...but I can only hope, I don't know if it did much for the volume. Then took some sand paper and sanded the whole inside of the runners and gradually used a less coarse grit. I only used 3 different grits tho, I don't remember what numbers. I then took some compressed air and blew all the shavings out, then used TB cleaner and a rag to get out anything lingering. Next I saturated a rag with aluminum polish, put it thru the each runner, grabbed each end and pulled it back and forth aggressively to polish the inside. I used similar technique with the plenum cleanup and polish. I sanded the outside a little with some coarse sandpaper then used 2 lighter grits...then polished. I could have spent more time on the outside, but I plan on painting it black so I figured I wouldn't sweat over it.GL with your manifold. Hope this helped out.
