INtake maifold question
mistaremy
Car: 1991 240 sx
Newbie alert complete moron excetera, excetera good we got that out of our systemthe sr20 on a pulsar gti-r has itb's I was wondering if I can match them up to a KA24 2cam yes,no or what I might encounter I broke : A student paying 900 a month on 1256 a month the baby is coming home 2morrow first mods wont actually be mods ; Switch clutch fan to electric, switch out crank pulley, switch from mechanical water pump to electric, Flywheel, DS, lightened acc pulleys I cant touch Oh! the A/C is shot so I'll do away with that **** too I'm anticipating 160 out back after I'm done 175 after the rebuild. Help with the Itb setup tho folks,
1991 240 250+K's
mistaremy
Car: 1991 240 sx
I am also aware I can match the GSX-R 1000 ITB to it but I rather not BASTARDIZE a beautiful child
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
mistaremy wrote:I am also aware I can match the GSX-R 1000 ITB to it but I rather not BASTARDIZE a beautiful child
You'll find out soon enough that the 240 gets BASTARDIZED with all kinds of motor swaps from different makes and front ends from japanese siblings.So don't worry about that
Chris859
And the gtir throttle body setup will not bolt on... for that matter, it doesn't just bolt on to other sr20's either - let alone a ka24. Not to mention, if it did, the plenum opening would be pointing straight into the firewall. If you got an adapter plate made to flip the plenum upside down, and bolt them to the head it would work. But on that budget I dont think it is happening. Stay with the stock water pump, it isnt stealing any noticeable amount of power. And electric water pumps are useless in anything but a track only car. You will gain more by ditching your mechanical cooling fan for an electric fan.
boznuttz
Car: MS13
I hope you have a lot of extra cash laying around. With an ITB setup on a KA, you won't be able to use your MAF and stock ECU. You'd have t run a standalone fuel management setup. If money is an issue to you, I'd really recommend not doing this, lol.
This is also the wrong forum for that question, but feel free to try asking in the KA24DE/ KA24E forums. These are the boost bug forums.
Chris859
Actually - assuming you made the throttle bodies fit... You could use the stock ecu, and maf. All you have to do is run a plenum on the inlet of the throttle bodies. In fact, that is how the gtir setup is designed from the factory - The toyota 4age ITB's might be an option with an adapter plate as well, because they also incorporate a plenum so you can use a maf.
boznuttz
Car: MS13
Chris859 wrote:Actually - assuming you made the throttle bodies fit... You could use the stock ecu, and maf. All you have to do is run a plenum on the inlet of the throttle bodies. In fact, that is how the gtir setup is designed from the factory - The toyota 4age ITB's might be an option with an adapter plate as well, because they also incorporate a plenum so you can use a maf.
That's similar to dumping some cash on a whole new catback exhaust setup..... and then welding a silencer on the end of it.
Chris859
Is it now? I guess nissan and toyota had their heads up their asses when they decided to use that setup... Gtir - yep, ITB's joined by a plenum... Rb26dett yep - ITB's joined with a plenum, 4age toyota engines, yep - ITB's joined with a plenum. All of them run great, which completely goes against what you are saying. Seriously, it has been done many times and always with great results - Using the plenum will not reduce the flow at all as long as it is capable of letting in enough air, which isnt too hard - do I need to do the math for you? There is no need to argue over something so simple...
mistaremy
Car: 1991 240 sx
the thing is I recently gave my car a full inspection and the the thing is I have 2 fans one on the rad and the clutch on the crank?? can I take the clutcher off now?
WDRacing
Stop posting non turbo related questions is the KAT forum. If it doesn't have to do with a turbo, then it doesn't go there. Thanks...
WD
mistaremy
Car: 1991 240 sx
WDRacing wrote:Stop posting non turbo related questions is the KAT forum. If it doesn't have to do with a turbo, then it doesn't go there. Thanks...
WD
I'm pretty sure this is what I see
Nissan Forums / Infiniti Forums - NICOclub » KA24E / KA24DE ForumTitle » Provide a brief description of your post.
Or did I mistake KA24E/KA24DE for the engine code for a friggin Turbo forum ? Piss Off If you have nothing to say
WDRacing
Thats cuz I moved it for you dumbass!!! It's my job to make sure topics stay in the appropriate forums. This is the second time you've posted in the wrong damn place. Thanks for being a douchenozzle
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
LOLDouchenozzle
dickie
Car: Killer Turtle
lol
mistaremy
Car: 1991 240 sx
douchenozzle!!
Well played sir
WDRacing
Fla240sx
the GT3 270ish hp KA-E's run ITB's on a plenum
as do MANY other race car setups, even engines from Nissans racing heritage, like R390's and sheeyot
it provides cooler air, and they can tune it better then just stacks........
if you make your plenum big enough and your ducting, I fail to see how it is detrimental in anyway but looks
mistaremy
Car: 1991 240 sx
I see i was gonna do it but however I deciced to - eliminate rust , gett the foot work done and rebuild or swap the motor to a rb2.5TT right now the prices are neck and neck 2500-3200 so I do the rust elimination ASAP. I had to drive it to school today to change the wheels to the snow bastards piss me offbecuz it finally snowed this week so now I got salt and water
1sikS13
Car: 1992 S13 240sx
And the new word of the day is.........................................Douchenozzle
