philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Sun Mar 30, 2008 7:08 am
You are right, there is no diagarm in the owners manual telling you which fuse is which. The fuse diagram is embossed on the back of the cover for the fuse panel. I've just read the back of the fuse cover:
- Bottom row middle - 'Meter'- Middle row, 3rd from right - 'Meter'- Middle row, 4th from left - 'Stop lamp'
Fuses for the remaining lights (tail lights, backup, head lamp) are located in the engine compartment.
To check the fuses, remove the fuse and use a tester to check for continuity. If you don't have a multimeter/tester then go buy one right away!
BTW, be very careful messing with the tail lights. Do not upsize the fuses or you could overheat the wiring and cause an electrical fire. Also, did you use an aftermarket kit for the LED's or did you assemble something yourself?
