INSTRUCTIONS!!!!!!!!!!!!!!
J30T_
Car: 93 Infiniti J30T
My car is a 6 cylinder and is running on 5 does anyone have insrtuctions on how to fix this?????? like step by step
bone_stock_240
Car: 1995 Infiniti Q45
Pull out the spark plug and see if you are getting any spark. That is probably the easiest thing you could do, and may solve your problem. My car was running on 2 cylinders, and that was due to bad plugs.
J30T_
Damn I didnt even know that bad plugs could cause that problem.....How bad is it for your car to run on less cylinders then its suppose to???
bone_stock_240
An engine needs fuel, air, compression and spark in order to work. If a particular cylinder is not getting one of those, then it won't work. You could check compression with a tester, and see if it is in spec. You could also check the resistance across your injector to see if it is working properly and delivering fuel. My plugs were pretty bad when I pulled them out. It could also be the wires. Since it is only 1 cylinder that isnt firing, it seems doubtful that it is a timing problem. You seem to have limited experience with cars, so the easiest thing to do would get new spark plugs and wires and change them yourself. If you haven't done this in a while, it is a good idea to do anyways. I try and change those things every spring. Other than that, you are probably better off taking it to a mechanic you can trust to get it fixed, or bribing a friend to come and help you.
J30T_
Ok great thank you for your help and yes I am very inexpierenced with car!!! It sux cuz i am a dude and know nothing about cars!!
HOW bad is it for your car to run with one less cylinder???
This is the section to post that question:zeroforum?id=24
bone_stock_240
BAD! You car will run rich, possibly damaging your catalytic converter, not to mention that it will vibrate like crazy, and you will get crappy gas mileage. If you really have to limp it somewhere to get it fixed, try pulling the plug wire that goes to the injector for that cylinder. At least that way you won't be putting as much unburned gas through your cat. Seriously though, try the plugs and wires first of all, and if that doesnt work, take it to get fixed. Don't drive around on 5 cylinders.
Everyone has to start somewhere. Just read up on the forums and the factory service manual, and don't be afraid to try some minor stuff yourself.
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
Please don't duplicate threads.
J30T_
Ok thanks man you have been a huge help!!!
