masa3 wrote:Sorry I need to install them too but I am a noob and dont even know how to trace the wire and where the ground is. If anyone can post some pics I would really appreciate it. Also how can I install a neon light kit.Thanks,Masa
masa3 wrote:can you please post a link to the wire tap things you metioned. So does that mean I have to cut the wire? Sorry noob question
I can go through step by step on doing both things (setting up a neon kit and getting those door sills to work) but I can only post the door sill on here. Pm me your email and ill email the step by step for the neons. But I must warn you, there might be some small difference being I have a truck and no longer have my V. But the concept will be the same.
As far as the ground goes, just take a self tapping screw and drill it into the frame with the wire on it out of sight (for clean look). And for the wire tap thing, theres no cutting needed, you just stick the tap over the power wire for the door switch and then the power wire for the sill on the other side. Its kind of hard to explain without doing it.
Heres the pics of both:
Self tapping screw -
Wire tap -
I will go into more detail once I do the walk throughs
