installing a turboxs MBC on my 1986 Z
A home for 1983–1989 300ZX owners!
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
i cant see how the hell to get to the wastegate to install this thing... no room from underneath, and from the top it seems i would have to remove my AC compressor and maybe some other stuff...
anyone know any tricks? or am i missing something?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
you don't ahve to access the wastegate actuator, just the hose taht leads to it, not sure where it hooks on a stock system, but on some of the older cars they referenced boost right at the turbo, you can plug that line and run a new reference line up to one of the ports coming form your manifold, and "T" ti in for easier access, and if you take the air inlet pipe off the TB to the turbo,a nd the heat shields by the brake booster you can get to everything pretty well
niemczykj
after about 2 hours and half a dozen cuts on my hand, i got everything situated... 10psi is pretty nice....
sorry for the frustration post
evildky
06 Nissan 350Z GT
lol, it's all good, glad you got it in, careful with the boost,10 psi with no intercooler will generate intake temps of over 200 degrees! this kind fo heat can lead to preignition, which makes pistons melt, and ring lands break, I highly recomend adding an intercooler
niemczykj
thanks for the concern.. i'm lucky enough to have 93 octane gas around if needed. i dont sustain those levels of boost for very long, but im taking precautions to prevent detonation, and intercooler work is in progress
Return to “300ZX (Z31) Forum”
