leerandallstewart »
https://forums.nicoclub.com/leerandallstewart-u146108.html
Wed Mar 17, 2010 2:53 pm
Next time you post, how about making the totle of the post more decreiptive?
Installation Advice - Fuel Cutoff Switch
That way when someone scans the forum, it will be much easier, and you will probably get more qualified responses.
That said, if you do want to go down that road, the easiest way to do it would be to start by tracing the wires on the fuel pump. One is a power wire, one is a ground, and the other only has power when you turn the key on. The last one is the one I would consider interrupting. Trace it back to the under side of the dash, and it should be an easy install.
