vape-one »
https://forums.nicoclub.com/vape-one-u118976.html
Sun Jan 31, 2010 1:01 pm
Left ohm Reading / Center ohm Reading / Right ohm Reading-----------.02 -----Nothing------ .02 middle*Stuck open I think
.32-.33 --------7.75 -------------------------------------------------- Nothing--- High ohm --- Right plug*closed I think
I think because the middle injector is stuck open is why I have no power an have no fuel pressure... Also the reason plug is so black.. An the one on the right that is really clean I think it is stuck closed... That is if there is such a thing that will happen in the injectors...
I know that the ohm are supposed to be in between 12~14 but I didn't know what to set gauge at..But I just learned it's 200.. All the Injectors from my old Z read .02 exactly...
I also took each coil out an checked the spark against the engine an all were working..
*****---------I need to know what the Ohm is for Coil packs an what setting to put my ohm meter on... 20k an 2k is what I was using with Ohm meter..---- If ya all remember my old post I was having trouble with my ohm meter.. There was a bad connection in one or both of the red/black tongs..
If you Z fellas have any comments it sure would be helpful...
Modified by vape-one at 8:59 PM 1/31/2010
Modified by vape-one at 9:03 PM 1/31/2010
