Injectors For CA18
Sil40sK
Car: '93 Nissan 240SX
'88 Porsche 911
'02 Ford Focus SVT
I know that this has been posted a lot, and I've search for it and I also saw a little bit of talk in the CA18 FAQ post, but I still want to find out all my options for my CA18. I've heard you can use stock RB20DET injectors, and I've heard some talk about using SR injectors, or DSM injectors, or even some RX7 injectors. Now could you use aftermarket injectors for an RB20 on a CA18? Or does anybody make aftermarket injectors for the CA? Also does it require any modding to put these injectors in?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Most top feed MSD style low impedance injectors work. DSM, RB, RX7.... SR are side feed, so those wont work.
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
RB20 injectors are smaller then CA18s.. i think you meant to say RB26.
But as c-rad said, anything top feed low impedance is the way to go.
Pete
Sil40sK
'88 Porsche 911
'02 Ford Focus SVT
alright guys, thanks. 550cc here i come
NeedCAforS13
Car: CA swapped S13 coupe
you know the stock maf maxes out before the stock injectors right? just making sure you're doing things in the right order... Also you'd better have a sufficiently man-sized turbo to run 550's
Sean
rico05
Car: 1992 RMS13 w/ CA18DET
And if you are looking at RX-7 injectors, make sure that you get the right ones. Series 4 (1986-1988) were low impedence, and can be used on the CA18. The Series 5 (1989-1991) were high impedence and cannot be used. You would optimally want a full set of either 4 primary (460cc) or 4 secondary (550cc) injectors. Remember: the 13BT uses 2 primary and 2 secondary injectors, so don't think that you will get all 4 injectors from one car.
Also, remember to get a set of 4 CA18 injector o-rings!!!!
F3600
ive got 550cc denso thats is a direct fit email me at [email protected] if you are interested
Sil40sK
'88 Porsche 911
'02 Ford Focus SVT
NeedCAforS13 wrote:you know the stock maf maxes out before the stock injectors right? just making sure you're doing things in the right order... Also you'd better have a sufficiently man-sized turbo to run 550's
Sean
Yea, I know it maxes out, I'm just running 10psi on my stock turbo and it maxed the hell out of my CA maf, so i'm using a KA24E maf but even that is getting close to maxing out, I'm picking up a Q45 90mm MAF and an S15 bbT28 soon, and I've already got an HKS adjustable wastegate actuator, so I figure that 12-14lbs of boost with some 440cc or 555cc injectors will get it done. Well than and a front mount, I just need piping for it though. Thanks everyone.
c-rad
Q45 MAF sucks... get a 300ZX one. The Q45 is too big and people have a nightmare tuning with it because it is inaccurate.
pulsar gtr
Car: NISSAN VEHICLES
I am using rx-7 550cc inejctors 1991, and yes you can use them but you need to illiminate your dropping resistor pack. I drove on them for a bit before I actually removed the resistor packs and they drove fine.
Also, yes, rx-7 do have only 2 primary injectors per engine, so if you order them make sure you mention that you need 4 as I ordered mine from some rx-7 store and they sent me two, they I figured that rx7 uses two, so I had to order two more.
PULSAR GTRRafi
