Injector Harness question
94Ig20
Car: 94 g20/ 98 trans am
On my 1994 G20, there is a sensor at the end of the injector harness.
We are having trouble starting the car, and it seems that this sensor is cracked/broke. I cannot find anything on it through AllData, can someone here shed some light on it?
The car tries and tries to start, and almost kicks over, but never can quite start. It almost makes it, the RPM gauge starts to move, and then its back to cranking.
I'm wondering if this sensor could be the culprit. Everything else is hooked up as it should be.
Any help is appreciated! Thanks!
djtorello
Car: 2008 nissan Sentra SE-r
Injector harness? maybe Fuel pressure Regulator?
94Ig20
I'm not at ALL familiar with these motors (I only deal with LS based pushrod motors). I will take a picture, and post it up to show you. It is the wiring harness that has 5 limbs off it. One per injector, and the 5th one on the end only has one wire coming out of it into the sensor.
I'll look and see if it is the FPR.
I'll post a pic today PM regardless.
