jt15833 wrote:if the turbo was in range of being properly fed by his injectors, would he be ok? Isn't it the MAF's job to calculate how much air is going in and adjusting for it?
I know that one issue is if this turbo maxes out either your MAF, or injectors, you will not have an enjoyable car. It will be in danger of blowing up.
it meters the amount of air, however the 02 sensors check for lean conditions.
if you are doing this at say 5PSI you may opt for a FMU like the KA-T guys do with their low boost setups and for go the tune. HOWEVER,
MBC(or even more for EBC)FMU (new is about 150 bucks for a good quality one)
vs
boost controllertune
your right about the same price.
