Infinititech folks please help
Crashtest77
Car: 2003 G35 coupe
Okay,considering I couldn't find the article after searching about 5 times for a how to get to your fog lights if you don't have access to a floor jack and stands, I'm asking now. I know it was said to just turn the wheels away from whatever side you wanted to change,that's easy, I was able to pull some of the fender well back to see where it was,but not sure what other snap in tabs,and screws to remove.Can you tell me where,or which ones so I can have a better view and be it more accessible to the headlight backing. Also I have new fog lights I want to install,obviously since I'm writing this,and I want to know if the high beams are integrated into the foglight housing or the reg xenon housing part.Also how the hell do I find the bulb for the side corner strip light in the headlight housing? I looked but didn't see anything,and couldn't feel it,it was also bright out,so there was a huge shadow in the wheel well.
Crashtest77
Car: 2003 G35 coupe
Bump, please help me with this tech folks.
WESIDE
Car: 2006 g35 coupe
I was planning on doing a write up on this but have been very busy making the good money that allows me to make the monthly payment on my beautiful 2006 coupe. Well there are a lot of little tab-snap things and you want to remove the wheel well. If you are doing it without taking the wheel off, like I did, then there are two tricky tabs that you might miss. One of them is directly above the tire just oout of sight, and the other, well, you now have to turn the weels in the other direction as the tab is behind the front of the tire on the engine side of the wheel well. Hope this helps. Wes
Crashtest77
Car: 2003 G35 coupe
That it does,now I just need to figure out,what type of bulb is in the corner strip lights for an 03 coupe,and I was able to see that bulb is located at the top of the strip,so now I have to figure out a way to get to it.Thank you wes
G_whizz
Car: 2010 G37 Coupe Sport
+ 1 for Wes!!
