dcaruso76 »
https://forums.nicoclub.com/dcaruso76-u194848.html
Wed Dec 07, 2011 8:04 am
I have a question concerning my Infiniti. I own a 2007 G35x it has about 40,000 miles on it and I’m am noticing that whenever it is damp or wet outside my car seems to be nudging forward or slipping when I reverse or pull forward into a parking spot. Also my VDC indicator and Slip Indicator illuminates on the dash and tends to stays illuminated. So my question is; what can be causing this? I’m thinking it maybe some kind of sensor problem but not sure which sensor. I’ve took it to my mechanic and he pulled the code and it comes up something about the brake fluid being low. So he checked that out and the brake fluid is fine. I’m puzzled because I only seem to experience this problem like I said when its damp or wet outside. Have you heard of this happen in G35’s? Any feedback you have will greatly be appreciated.
