mdmellott »
https://forums.nicoclub.com/mdmellott-u292054.html
Wed Feb 23, 2022 9:02 pm
I don't have EGR on mine but I do have several of those type harness plug mounts. They can be a pain to remove when they get cruddy under the plastic locking tab and in the guide slides of the connector. The sheet metal mount it slides onto has a small square cutout in it which engages with a locking tab on the plastic connector. A little WD40 or silicon spray will loosen up the crud under the plastic tab, making it easier to press below the thickness of the sheet metal. It will only depress just enough to clear the sheet metal to slide it off at the same time. Every time I have to undo one of those, I wish for a third hand to get it apart. Typically, it's usually in a position where I can't even see the tiny tab that needs to be pressed with a small screwdriver.
