Altiman94 wrote:i/h/e/p don't give any horsepower, then simply free up wasted horsepower. Theoretically, you should be able to get 155 wheel horsepower by freeing all the lost hp throught the engine/drivetrain. But everyone knows that is nearly impossible.
A well designed complete system from intake to heads, cams, headers, and exhaust that are designed to work with each other and compliment each other can make HP. This is especially significant with header and cam designs where if properly matched can create some very good exhaust pulse tuning which actually draws air out of the cylinders. In some extreme cases and for a short RPM range, it can be set up to pull air in all the way from the intake. This will be found more on high overlap cams which means it will likely be unstreetable.
